Yes, you need a C (sometimes series RC circuit there for compensation. [/quote] The value may be optimised in regard to the application (high closed loop gain requires less compensation, positive gain requires more than negative gain)thermionic said:If you just build a circuit with the op-amp, merely putting a feedback resistor + divider resistor off the inverting input to pin 8 and Gnd respectively (e.g. as a non-inverting topology), you're likely to get an oscillator, not an op-amp - right? In order to stop it oscillating, you need to put a small-value cap between pins 1+7 (aka a 'cdom' cap) - correct?
Pin 3 can be used for a number of things: increasing the LTP current (for more speed, low source impedance noise optimization...), also for so-called "current feedback", eliminating Q2 and directing NFB to Q1's emitter, and probably other things I can't figure out...Seems like the Studer guys have left open a lot of possibilities for optimisation. Same thing with pin 8, which allows increasing the output idle currentSecondly, what does pin 3 do?
You're right, these are the most likely causes of noise build-up. Other possible, but less likely cause is contamination of transistors due to porous package (it happens some time). Don't neglect the possibility of dirty connectors or dirty PCB. Anyway, all of these problems are quite easy to trace and solve once and for all.Thirdly, I read an 'opinion' at another audio forum (the name of which I won't mention...) stating that even the later op-amps that use the trusty BC550/560 combo go noisy over time in the A80... Why might this be? Surely this can only be due to an electrolytic drying up, or an issue with a passive?
Oh interesting. It might be acting as a feedback bypass capacitor like you’d see in the standard common emitter amplifier.I have used this opamp in several products. In one case, I came to the same conclusion as you and eliminated that cap. Turns out the voltage range is drastically reduced by taking that cap out. I don't know why, but in that case putting the cap back allows the output to swing the full range.
