cariocaman85
- Joined
- Sep 24, 2011
- Messages
- 121
Dear All,
A regretted friend of mine gave me his STUDER A807 that had been in his attic for a long time.
After gently cleaning it, it is working almost fine, transport is working well, but I can't get no playback sound from the tape.
I sent a reference in the line inputs and it goes right through the output (and inside monitor), even in play mode, but nothing is coming back from the tape.
Looks like the Varispeed, Nab and Insert switch are broken, but I think it shouldn't be this problem, maybe I'm wrong?
I can't see no jumper in the manual that would do that, but I'm surely mistaken.
This is the model without the VUmeters.
By the way it has not been recaped.
I think I will do it, but don't know if it can influence the logical routing.
The fuses are all good and passing.
It seems to be locked in Input monitor mode, but I do not know how to change this.
My version is without the Vu meters and I don't have no Input/repro control.
My guess is there is an automatic switch from input to repro when play is engaged, but I'm not sure.
Enquiring through the service manual tells me that a MC14053 is analog switching between Normal Reproduce path and the input signal. Could be it but as it is doing this on both channels, I suppose it is the command signal of this switch that is not working. I need to find from where this signal comes
Thanks a lot for your help,
