stuffing the box-pics
mich
Israel
here is a diy of parts and pieces i had lying around...
on the left-2 channels of 1272 ,with fixed gain on both stages, 5k pad pot, oep's at the input,and some transformers i had to "hang" on the output,and take the output signal from the cap(collector of the output transistor)-
on the right -2 channels of 312,melcor diy,also with oep's ...,and a 12 position gain switch.
all of the outs are unbalanced (i run very short cables to the soundcard's inputs,and can always add output transformers if have the need for them).
also i made a small board for the mic input with pad,phase,and phantom.
power supply is one 0.5A transformer giving +24V,+48V,and +12V for the relays, and another 0.5A transformer giving +/- 18V for the api clones.
it was lots of work.....wiring,fitting things in place(trying to fit in those 4 small mic input boards was a challenge.....),drilling and all the other obvious stuff....But im very happy with the results :))
sound is grreat,no hum ,buzz,or anything like that,and some sweep tests i did with the audio tester showed good results...
i'll try to post samples when i'll have them.
oh, and i still have to do the instrument inputs wich i already drilled on the frontpanel....any sugestion on that one?how to interface Hi Z to the transformer's inputs?
thanks
Looks great!
That's inspiring. Can it make a cup of coffee too?
Someone makes a hi-Z converter for DIY preamps. I can't remember which site it was..... The guy makes power supply kits, pramp kits, etc.
I'll try and remember. The converter was a small IC based pcb.
good idea...stop diying and buy some ready made stuff...
actually it is a good idea,i already have a quote from JLM for a couple of his output transformers for the 1272.....so adding a couple of his Very Nice DI cards(and components)for 28$ each wont hurt me too much....i only have to wait for some money to come in...
thanks for the advice. :thumb:
[quote author="mich"]good idea...stop diying and buy some ready made stuff...
thanks for the advice. :thumb:[/quote]
Joe's stuff goes together so easily that it practically builds itself...
Its kind of scary...
:thumb:
