rascalseven
Okay, it's late, and I'm not getting my mind around this at the moment. I just finished a tube mic and am doing pattern switching with a relay, and built a little 12vdc supply for this relay in the power supply. Using an Alcatel 12v relay (360 ohm resistance on the coil) my control voltage drops to just over 1 volt when the relay is engaged. It 'clicks' (twice, like a flam on a drum), clearly not staying engaged (with only 1 volt steady on it). I'm regulating this voltage with a 7812 regulator, and it looks good until I engage the relay.
I'm sure this is a simple thing to fix, but in other things I've built I've not had this problem. What obvious thing am I overlooking in the middle of the night???
Would be mucho grateful for any light shedding.... thanks.
JC
JC
