Suggestions to add to my Simple OT design aid app
dougsta
Active member
Edinburgh
Last March I created a very simple output transformer app to help wind transformers for valve amps, runs on windows/mac/linux. I also did one for power transformers.
It just uses the RDH4 ch5 for the theory and adds a lookup table to suggest a wire gauge (AWG), a toggle for SE/PP (no air gap calculation, I figured a layer of kapton tape or pressed paper is close enough, leave it out or add another if it doesn't sound right).
I included a few templates to load, eg 6V6 tweed type push pull 6K6:8Ω.
My next update will add more templates and a toggle for using metric units (mm for core dimensions and Tesla for flux density) or Imperial units (inches and Gauss) I didn't use Lines/square inch/fathoms/bushel as per the RDH, 1T = 10000G = 64516 LSI.
It also restricted the sec imp field to 2 digits, 1-99Ω as I planned on only using 4, 8 and 16Ω speakers. @ruffrecords suggested expanding this to include at least 600Ω, I'll can change this to 5 digits so max will be 99999Ω for pri and sec impedance.
Another idea is to add % taps for UL.
Maybe a user option to save/load templates.
Feel free to throw some ideas at the wall and see what sticks...
Doug
    115.6 KB
cool!you can build programs for each size lamination than can be can helpful,
and you can add leakage inductance formulas to your design program,
i do mine in excel, if you want i can send you the files, cj
Thanks CJ, that would be great.
There is a program by Yves Monmagnon that goes into a lot more detail on the magnetics and copper and Pri/Sec layers and targeted at HiFi link:
http://www.dissident-audio.com/OPT_da/Page.html
User guide is in French ( ok for me, I lived and worked in Paris for 9 years, google translate does a reasonable job on it)
Doug.
