Svart
Does anyone actually sum both channels of a stereo/dual mono buss to just one channel? My console has dual mono buss strips that can both be assigned to either left and/or right via a switch. this means you can select left for both or right for both or as I usually use them, left and right respectively.
How about PFL on buss channels? Solo?
Would you rather have mute via Jfet or relay?
how about the switch type? toggle or pushbuttons?
If you haven't guessed already I am working on simple summing buss channels. DOA w/servo output etc.
Any features that you might like, post them here and I'll take them into consideration.
The front end could be simply passive or could be active through matched BJTs ala SSL and others.
Although this is for an Alesis X2 frame, interconnecting cables and grounding bar, the design should be easy to get working in just about anything.
More on this later..
