Superlux S502 MK2 test, teardown and improvements
They look indeed quite similar, including the capsule to head amp interface.
What raised my eyebrows was how the mic was used with the capsule at one end of a boom stand and head amp at the other end. I'd expect he long wiring in between to add a lot of capacitive load, causing significant signal attenuation. Not to mention potential microphonics from vibrating cables in the boom, e.g. due to stage rumble or handling. Or would the capsules be electret types with built-in JFET? Has anyone seen such a set up before?
Jan
That is not correct. At least Schoeps devices include a JFET buffer in the capsule holder. Long wires are therefore no problem...
Hi All,
some questions arised regarding the output voltage and SNR with my "repair kit" in comparison to the original circuit.
S502 1st version:
Free Field Sensivity -40,3 dBV instead of -36 dBV
Electronics noise -127 dBV(A) instead of -114 dBV(A)
Self noise 16 dB(A) instead of 18 dB(A)
Max. SPL 140 dB instead of 134 dB
S502 MKII:
Free Field Sensivity -37 dBV instead of -38,6 dBV
Electronics noise -127 dBV(A) instead of -120 dBV(A)
Self noise 14,5 dB(A) instead of 16,5 dB(A)
Max. SPL 137 dB instead of 134 dB
So long MicUlli
Sorry, but now I'm confused... In your first post, you said the Schoeps and S502 MK2 capsules are interchangeable. And the capsules of the latter are without JFET and not pre-polarized, so then both should be regular condenser capsules. So do you mean to say some Schoeps capsules have a JFET or all?
Jan
Hi All,
time to answer some questions:
1. I only sell the repair kits inside Europe.
2. The "repair kits" include pcb and ALL necessary components and a detailled assembly/test instruction.
3. Payment only by banking transfer, shipment via DHL, you get a tracking number.
4. MBC5X0 repair kits still available, S502 repair kits under construction.
5. Prices only upon request via PM, pls be so kind not to post them in public space :)
MicUlli
I'm sure some of us here in the US would like to make our 502's better, I know I would. Is just the PCB available to the USA? Regards, Chris.
I strongly suspect it's because this is a CML-300 😉
As stated in Ali description
Yes but the Ali mic is HTDZ brand, http://www.htdzpro.com/ (however, you can't find CLM-300 there) and the HTH is the Korean brand, also the FR's are different. Is the Ali mic a Chinese copy of a Korean microphone which is a copy of a German microphone? Anyway, there is a third brand, Kateluo, with another identical CLM-300 microphone: https://www.kateluo.net/cms/show-30.html
Btw. you can use Google translate to read Korean or Chinese pages.
I agree that the specs/graphs are different, but the biggest difference between all these and the schoeps is the use of electret condenser capsules
Where to buy? Can't find them in Ali nor anywhere else
I'm referring to Jan's post #77.
But beware! It may well be, as @mhelin said: " Is the Ali mic a Chinese copy of a Korean microphone which is a copy of a German microphone?" His remark is highly probable.
Also, first check links shared above by @mhelin.
He did a fantastic detective work.
They seem more trustworthy than Ali. Thread carefully.
Do not get carried away 😉
Hi guys, I think we have deviated from original subject which was : is it possible to improve the Superlux S502 (and MkII) and how.
Let's summarize :
@MicUlli has done much measurements & tests and decided to design a original board which should improve the mic. Then he proposed to sell a whole kit board + components. We were 16 or so to "pre order"
Then @jp8 send the idea of using S502 1rst version capsules and marry them to a Schoeps-like circuit, and for that, he began seeking for a donor-body with a thread compatible with Superlux capsules.
Am I right here ?
For my case, I am concerned to know how things go for @MicUlli project, when we'll have to pay him and how much, and when will we be delivered...
Let's please focus on what we discuss here : a (very) nice & cheap mic which, plus that, could be improved.
(Korean - chineese stuff mics at ~70€ is another subject I guess)
Make it easy : spend 105~150€ for a really nice Superlux ORTF and get @MicUlli kit and you'll have an incredebile & unbeatable mic for its price ! (you can also use it as one mic only if you want so)
With respect :)
