> Oh wow I didn't know we needed that much..
Sorry; I thot you knew what "SVT" spelled.
"Portable" (ha!) stage amp, intended for bass but has been used for guitar. Re-issued in many versions, some quite lame self-rip-offs. The original Ampeg SVT uses six large tubes working from 600V-700V and makes an honest 300 Watts clean power.
There was a short fad: the Fender 300 was similar, and Marshall attempted 400 Watts on similar plumbing (didn't survive stage abuse as well as the Ampeg or Fender).
Output stage efficiency is over 50% so the total DC sine-test demand is closer to 500W nominal. Of course speaker impedance varies, guitar/bass is often overdriven, so it should support more than 500W DC load without crap-out. 700V 1A is not a bad goal.
If you size this up with 50/60Hz iron, and put a handle on it, you understand why these amps don't go to more gigs.
> tap into the HV side of the switcher and regulate down
Regulation is NOT needed. These things ate raw transformed-up wall power and it never hurt them. (Considering the way wall-voltage has risen in the last 30 years, and the occasional way-out wall outlet, it might be nice to cap the nominal 650V B+ at 700V.)
"tapping the HV side" is equivalent to a Hot Chassis amplifier and is NOT safe. We need galvanic isolation for life-safety.
The way my small mind sees it: the generic PC power supply takes 115V/230VAC and rectifies to 330VDC. A half-bridge slaps a winding. Two diodes and two caps could recover 328VDC, non-isolated. Or the winding is CT gets 330V peak per side, and an identical winding (without CT) to a doubler would give 660VDC. Which is what we want. But I think the CT driver is rare.
You can buy a "1,000 Watt" PC power supply for less than a SVT transformer. If the switcher transformer could be re-wound (AFAIK, a major pain), we'd remove most of the secondaries and wind a new secondary similar to the existing primary, or twice as many turns one gauge smaller wire. Ground one end, a doubler spews +/-328V; ground the "-328V" instead you get +328V and +656V DC, which is sweet. Toss a few turns on to get a nominal 4V winding to tickle the original 5V sense. Adjust so that it is normally un-regulated, but will cut-back if "656V" soars much higher.
You could even wind for heaters, and they can eat supersonic 6.3V just as easily as 60Hz or DC. But there is near 100W of heaters, our total load is 800-900 Watts, our winding skills are dubious, we may be pushing our luck with a "1000W" rated PC power supply (the makers know you don't have 1,000W inside a PC case except maybe for a few seconds at spin-up).
The other thing I see: fast-recovery diodes don't come in HIGH voltage. The doubler will need 650PIV diodes, plus enough safety margin to survive a gig in downtown Lodi or out in a field on a generator. And if normal-abuse means ~~1A DC, doesn't a doubler need "2A" diodes, with ample margin above the nominal stress? I don't know how fast or how fat we need, but I suspect this is not a common part.
> http://www.qscaudio.com/products/products.htm
Yes, at the ~~100V-200V level, the diode voltage rating is less of a problem. (But must be HUGE current rating in some of those amplifiers!)
