Ive been reading various threads about this and wonder if anyone has done the same and noticed sonic differences .
I moved my in/out transformers and op amps from 2 old fabio v3 312 preamp cards to capi vp25s .
My question is - will using the the components slated for the ca26622 ( zobel ect ) up to the op amp , hinder the performance of the cinemag cmmi 8-apc .
The Cinemag needs to see 100K followed by 9K76 & 22pF .
https://cinemag.biz/mic_input/PDF/CMMI-8-PCA.pdf
The ca2622 in the capi vp25 has different values .
https://capi-gear.com/catalog/images/build/VP25-26/VP25-Rev-C-Schematic.pdf
what components would you suggest I swap out for the best performance ?
is just dropping the 150k to 100k the major change or should other parts of the vp25 be changed as well /
there is a quote in another similarly titled thread
"if you're swapping in an API type pre like Fabio's boards, Reichenbach at Cinemag said just the 100k R, without the extra 9K76 & 22pF cap, should work fine...
If any one has any ideas please let me know
