Switch Wiring Cheat Sheet?
hodad
ATL
I'm trying to work out how to do some slightly fancy switching using two 4PDT switches for a guitar pedal, & I'm struggling a bit. I seem to recall some sort of picture or document being posted on the list that illustrated a few different switch wiring strategies, but I don't even know where to begin to look for it. Can anyone point me to something here or elsewhere that covers this sort of thing?
guitars are my thing🥸. what are you wanting to acheive. i have built guitars with two humbucers and a 5 position strat type switch. pos 1 pu 1, pos 2 pu 1&2, pos 3 pu 3, pos 4 pu1 single coil, pos 5 pu1 single coil & pu 2. you can also add other otions with push pull pots such as series parralel or anti phase. give me clue what you want and i will try my best to work it out for you.
Which doesn't tell what you want to achieve.
Ther are many ways for wiring a switch, that depend mainly of what type of selection you want to make.
Also, the type of switch can make a difference. Is it a toggle switch or a rotary?
a couple of pics from a bok i have hey may give you some ideasIMG_20231001_102518.jpg
hope this helps mate.
I like kind of a truth table method.
Start with the output results or the input choices. Either way you are programming inputs and outcomes into the fixed possibilities of the switch. Sometimes a position’s contacts might only have interlinking, yet route a different state. Here the NC contacts are your friends.
Mike
so what are you actually hoping to acheive with these switches i guess they are push types as you mentioned peddle (stomp box?).
I'm trying to get the most out of a very simple distortion circuit without any major alterations to the circuit (ie, no additional semiconductors.) I think I've got it sorted for now. All that's left is to build it & see if it works the way I'm envisioning it working.
