So I've got an interesting problem. I own a Tascam 85-16 and it's in great shape overall. One problem I've noticed recently, though, is a hum coming from the sync head, not mechanical hum but electronic hum leaking into the sync amp via the sync head. The more channels I arm, the louder the hum. It's barely noticeable on 4 simultaneously recorded tracks, but if i keep arming more channels, the hum increases and it's clear that it increases with every single channel, so it's nothing to do with groups of 4 or 8 for instance. And the hum only starts once I push "Record".
The hum can be heard on all channels of the Sync head, regardless of said channel's safe/ready status.
I've recapped the psu completely, and while it removed some other issues, it did nothing for this. I also recapped the board that houses the master oscillator since I thought this hum might somehow sneak into the bias signal. No luck there either.
The machine is completely quiet otherwise, and all the power going to amps, N/R and transport are clean looking on my scope.
If anyone has encountered the same issue, I'd be very greatful for some guidance.
Emil
Emil
