Hi all,
I've been lurking in the other forum areas for a while and have finally strayed here.
Obviously this is my first foray into mic-DIY, and as such I thought it prudent to get a bit of practice in before moving on to the more involved stuff (C12/ELAM and U67 are on my to-do list). I've had a pair of Thomann.de SC140s kicking around for a while, and while I like them as they are (if not, they are a little peaky) they seem like good donors for modding.
I have seen a few posts regarding this mic, and in particular outlines of mods by M.Joly that I'd like to implement as practice.
The first is to modify the head basket, as I understand it the more open basket will help control HF peaking (good for my wants). I intend to cut away the strip between the slots and therefore open it up a bit. Hopefully, if I am not too ham-fisted, I should be able to re-use the mesh inside as it looks pretty easy to remove.
The second thing I intend to do is replace the caps with non ceramic varieties. Are WIMAs good to go for? A kind soul shared this schematic but unfortunately I cannot remember where or who. Sorry. From photos of his board, the mics were populated with SMDs. I've looked over the boards and as far as I can tell they share the same schematics with differences between device types.
C1 = 153 = 15nF
C2 = 333 = 33nF
C3 = 22uF 50v
C4 = 22uF 50v
C5 = 104 = 100nF
C6 = 1uF 50v
C7 = 333 = 33nF
C8 = 333 = 33nF
C9 = 471 = 470pF
C10 = 332 = 3.3nF
C11 = 102 = 1nF
C12 = 102 = 1nF
C13 = 104 = 100nF
C14 = 153 = 15nF
C15 = 153 = 15nF
C16 = 100uF 50v
C17 = 153 = 15nF
C18 = 153 = 15nF
C19 = 6.8pF
C20 = 27pF
C21 = 333 = 33nF
Q1 = 2n5401
Q2 = 2n5457
Q3 = 2n5551
Here's the board
I can see quite clearly that the 'orange' caps are ceramic, I guess that the 'mint' caps are also ceramics?
I intend to document the process including samples of the differences it makes and compare alongside the other half of the 'stereo set'.
If anyone has any suggestions, things to avoid, things to definitely try etc that'd be great.
C1 = 153 = 15nF
C2 = 333 = 33nF
C3 = 22uF 50v
C4 = 22uF 50v
C5 = 104 = 100nF
C6 = 1uF 50v
C7 = 333 = 33nF
C8 = 333 = 33nF
C9 = 471 = 470pF
C10 = 332 = 3.3nF
C11 = 102 = 1nF
C12 = 102 = 1nF
C13 = 104 = 100nF
C14 = 153 = 15nF
C15 = 153 = 15nF
C16 = 100uF 50v
C17 = 153 = 15nF
C18 = 153 = 15nF
C19 = 6.8pF
C20 = 27pF
C21 = 333 = 33nF
Q1 = 2n5401
Q2 = 2n5457
Q3 = 2n5551
Here's the board
