T pad attenuator and phantom power
its bad,what mic are you using? is it yours?
a t-pad is gonna throw off dc balance/cmrr.
is pad stepped switch or pots? either way noisy or pops when adjusted, mic may not like pops especially.
We usually see U(balanced l)  or perhaps H (balanced t) on mic pre ins
There's no good reason to use a T (or a H pad) pad between a mic and a preamp. The additional resistor(s) on the preamp side increases the source impedance for no reason. Just increases noise without any significant advantage.
As shabtek says "is gonna throw off dc balance/cmrr.", that's all. In particularly adverse situations (intense RF, temperamental preamp), it may impair audio quality, but generally would go unnoticed.
Phantom power will have differing series current limit R in each leg.
Pretty much every vintage remote mixer with multiple inputs used a T or ladder on the input, so it was a standard.  50+ years ago.
