> Take Five Minutes And Help
> 100ma at 200v = 20R plate resistance?
> and 50ma at 125v =6R?
> That seems off to me.. I almost know it's wrong...
{sigh...} Looks like more than 5 minutes of help needed.
100ma at 200v is 2,000 ohms. Where do you see 20?
When befuddled, don't work in "milli"anything. Convert to whole units. 100mA is 0.1A
Ohms is Volts divided by Amps.
200V/0.1A is 2,000. If you forgot your elementary education, any pocket calculator will figure this for you, or Windows Calc will give an almost-right answer.
That is the Large Signal or "static" plate resistance for 200V 0.1A. See red line.
Tubes pass current one way, audio swings both ways. We usually set a large DC current, then swing back and forth around that point. See blue line. We can swing 70V and about 70mA (0.07A), so the Dynamic plate resistance at this point is 1K.
But get back to the real world. The 1626 has a plate dissipation limit of 5 watts (orange curve). 200V at 0.1A is 20 Watts! (do you get the same answer?) In audio, we usually can't beat the plate dissipation limit. (In Class C radio, we can peak much higher, and that's what the 1626 was sold for, and why the curves cover territory way past the steady-state plate rating.)
A likely operating point for audio might be near the green line. Here the curves are steeper. The dynamic plate resistance is around 50V/25mA which is.... 2K. The Static plate resistance however 175V/30mA or about 6K.
Large-signal design can not be done correctly from simplified single-number data like plate resistance. The curves are too bent for any single-number to be true in all cases. However you can rough-sort tubes by the slope of the zero-bias grid line as it approaches the plate dissipation parabola, because that is usually the upper limit of how much current you can suck out of the bottle. (You can go higher if you drive the grid positive, but in audio it is too hard to do that and meet a distortion spec too.)
Small-signal design, where signal swings are MUCH less than supply voltage, can often be done well-enough with just a rough idea of the dynamic plate resistance at an operating point similar to what you plan to use.
There was one single ended power amp with an output of about half a watt that used a 1626 tube ... I've seen other low power triodes used in line stages and wanted to design someting for this tube because it has not been done yet that I know of - I'd have to really design it myself
No you don't. What is the difference between a speaker output stage and a line output stage? Just power and impedance. Speakers need many-watts at a few ohms. Lines need a part-watt at hundreds of ohms. And in this case you HAVE a part-watt amplifier... you just need to find a transformer with 600Ω secondary instead of 8Ω secondary.
Typically, speaker-amps are more desperate for power than line amps. OTOH the complete audio path (artist to listener) passes through one speaker-amp but maybe many line-amps. You want low distortion in a line amp. So you might also increase the tube load impedance (primary impedance) which drops power a little but drops distortion even more. For old-school small power triodes, you may run into trouble winding a good high impedance with high enough inductance and low enough leakage. For 1626, a 10K:600Ω ratio may be a good first try.
