samgraysound
JohnRoberts said:That device does current limiting in one direction.. a bad transistor there could upset the works...
Bias adjust is working now, and Vbe on output transistors is looking normal too.
sweet.. 8)samgraysound said:Bias adjust is working now, and Vbe on output transistors is looking normal too.
JohnRoberts said:sweet.. 8)
JohnRoberts said:The drinking lamp has already been lit here so don't expect good answers...
but... you did have a bad transistor in the current limit circuit, if that circuit is still wonky it could cause the premature clipping in one direction.
The symptom is consistent with bad current limiting in one direction.samgraysound said:This is actually the other channel that I thought was working.
JohnRoberts said:The symptom is consistent with bad current limiting in one direction.
Diodes are pretty easy to test with modern VOM but cheap... back at Peavey we paid less than 0.01 each for simple signal diodes, but we were using more than 1 million every month.samgraysound said:Alright. Replacing the diodes seemed to solve it. Back to load testing.
Sam
JohnRoberts said:Diodes are pretty easy to test with modern VOM but cheap... back at Peavey we paid less than 0.01 each for simple signal diodes, but we were using more than 1 million every month.
Glad it is working .
I can imagine "soft" failures that express differently when reverse biased with significant voltage but these are generally not seeing much reverse voltage (from memory). The most common failure mode for diodes is short circuit in any direction.samgraysound said:A mentor once told me that diodes can test good but still fail under load, so if they are suspect just replace them as they are so cheap anyways. Don't know if that is good advice or not honestly. In this case D911 and D913 both tested dead out of circuit.
That was what they paid back last century, but what I found remarkable was using over a million per month with no reported failures that I could find (I looked). It is entirely possible that some were bad but did not reveal themselves as used.I paid $0.019 for my 1n4148s. Nearly double what Peavey was paying!
