rubinstu
Active member
- Joined
- Jan 10, 2019
- Messages
- 37
In my DIY ribbon mic project, I'm getting a significant amount of hum. This is expected since as of now, I have zero shielding at all! I think (hope) that encapsulating the transformers will be sufficient. You can see the photo of the preamp / transformer below.
I am considering one of these two options:
Magnetic Shielding Film MCF5 3 Linear Feet
or
SICCOMA Faraday Cloth Tape Double Conductive Cloth Adhesive Tape for EMI Shielding, Wire Harness Wrap, Grounding, Guitar Interference Signal Blocking, Electrical Repair (1 in x 66 FT)
from Amazon.
I'm looking for cheap and easy but good enough.
Do you think these would get the job done? Which would be better?
Does the magnetic shield need to grounded (electrically attached to the signal ground, the case of the XLR, etc.)?
All thoughts are appreciated!
or
from Amazon.
