> schematic wants 19v input.
Says 21V.
> i had a huge low frequency boost.
The schematic you posted shows output cap C8 as 1,000uFd. (Abbey cited a C5, which suggests he was commenting on a different plan.)
1,000uFd should be flat far below 20Hz.
It would help a _lot_ to say what transformers you used and how-much bump you measured with what loading.
If C8 is very-very-very sick, dried-up to 10uFd, you will have bass trouble. Tacking a 1,000u across it will confirm (or refute).
> get the level up somehow (its at -14db now). im simply afraid of clipping the preamp trying to get a proper output level.
Afraid?? Clip that thing! Can't hurt the circuit.
The schematic you posted can drive 200 ohms to about 5V RMS. Has gain of 15, so needs 0.3V input.
(R1 lets you trim gain down to unity.... it should be set near-max, a bit back on one to match L/R pairs.)
Should be little problem finding 0.3V to drive it.
5V should do fine work all around the studio. Leaves 16dB headroom above 0.775V, so you don't really want to meter for +4dBu (only 12dB headroom!). Metering for -10dBV (Tascam) leaves a very ample 24dB headroom.
A custom 200:600 transformer only gives voltage-gain of 1.73, so 8.6V max out, or another 5dB. That barely gets you to +4dBm territory. A "150:600" with light loading (>5K) also gets you there, but verify the high-frequency wiggles with such loading (5K and 1Meg).
> Says 21V.
The limit appears to be C4 which runs 0.6V below point A which is nominally half-voltage. So on first approximation the maximum supply voltage is 2*(10V+0.6V) or 21.2V. The half-voltage may differ, R2 seems to be selected, but in any case C4 is run way too close to the edge. Unless it is super-vintage, I'd replace C4 with new 16V-25V unit. C4 is critical to sound (gain and distortion) so if in doubt rip it out. C2 could also go next-higher voltage rating. C7 is good to over 25V total supply, but is essential for getting large output in low load impedances.
