Tabitha - DIY MS mic from JLI
Neumann did that in the km56 and km86 microphones, if it worked well enough for them…
    247 KB
I think what Gyraf is discretely hinting at is the figure 8 looks side by side rather than back to back. Hard to tell.
The Oktava adapter makes something kinda like the Neumann KM86 approach but with even more space between the capsules. Many criticize the spacing of both, but it does work. Side by side would be a whole different cup of fur, but I’ve done that satisfactorily (enough) too.
Neither will compete with the pattern control of a proper single capsule approach
Also hilarious is the statement that Blumlein described MS but there was no equipment available to execute the technique.
They do fig-8with two cardioid capsules, I wonder if that works well, pattern-wise?
I did an OPIC Mid/Side mic based on this format back in 2022. (See here: https://www.opic.jp137.com/index-ms.html )
The side capsules were 2 x TSB160a Fetless electrets, wired in series, and mounted side by side. As M/S mics are not generally used in a close mic configuration, the small offset seems to make no appreciable diffference. ....The idea works well.
Well, they're half right; what Blumlein didn't have available to him was a cardiod mic to do what is now the most popular form of mid-side; with a cardioid mid. The mid-side he describes in the patent was implemented with a figure 8 mid.
So patent describes two cross-8 configurations: mid-side with a fig-8 mid, and the config that now bears his name (which he actually called 'XY'), crossed '8s' at 45 degrees L and 45 degrees R.
At the time the 'splayed XY' was theoretical (though I'm sure he knew that mixing an omni and a fig-8 would produce such a pattern, such 'combo' mics [such as the Altec Birdcage] weren't yet commercially available).
    106.8 KB
I use MS with M figure 8 as much as I do omni and cardioid. Given the choice of two 8’s in MS or Blumlein 45, i more frequently use MS for the stability of the center image with width control.
