[quote author="nielsk"]most of the gear I have worked on that actually use 2142's (Amek has used them extensivly, just to name one..) tie the force and sense lines together and then use a polarized electrolytic, often 220uf, on the outputs. When I tried the 1642 in this way on the balanced mix bus, there was a drastically high noise floor. I would expect problems if they were used as a drop in replacement for the 2142's. They are also very sensitive to power supply high frequency noise, and must have 100n decoupling caps very close (not so with the 2142's)
That being said, with these devices implemented as per the manufactures spec, they work fantastic[/quote]
nielsk,
I am curious about the problems that you encountered. I would not expect any problem with shorting the outputs to their respective sense terminals (in fact, the parts are tested this way), or with output AC coupling capacitors. Your comment about increased noise makes me wonder about the source impedance driving the part. All of these designs have inherently high common-mode noise gain, and an imbalance in the feedback network will convert common mode noise to differential noise. The 1646 is more sensitive to this than the 2142 or DRV134, in part due to the lower input resistance (which yields lower noise when they are driven with a 0 ohm source). We have found that some customers, despite the cautions in the datasheets of all three parts to drive them from opamp outputs, drive the part via a higher source resistance. This may make what was an acceptable cost/performance tradeoff (saving an opamp) with the SSM2142 or DRV-134 unacceptable with the 1646.
As to the 100 nF decouping capacitors, yes they must be close to the IC, as is the case with most high-speed devices. You may have seen stability issues if they were too far away. I would expect HF power supply rejection to be at least as good as the competitive parts.
If you could let me know the details of the circuit that gave you problems, we can investigate a bit further. Feel free to PM me if you like.
Regards,
Gary Hebert
