In design notes... Check diy pedalwhat is the file from the That cooperation?
to have a look at this circuit.
Thanks for the link... Yes the quadrature reduced ripples... Everything from rectifier to Cv out smoothed... This technique gives an analytic extraction of the envelope as declaredHere's a thread from a guy named puretube who did an envelope circuit using a "90-degree", aka dome filter
https://www.diystompboxes.com/smfforum/index.php?topic=25313.0to reduce ripple.
Might be what riciyobs is looking for, or at least a lead FWIW
Fine! Thank you so much... I ll experimentYou might want to look at the Weaver Alignment for the Dome filter. It has less ripple than the Studer.
https://proaudiodesignforum.com/forum/php/viewtopic.php?p=16533#p16533
R. B. Dome was the name of the "inventor": The Studer "90° Filter" Stereo to Mono Summer/Recorrelator - Pro Audio Design Forum
did ya check the Befaco slew limiter simulation?did RC circuit phone app a good evaluation?
it seem that now att and rel controls are working fine
Yes a quick check... But in few time I couldn t understand... Have to find time... I m reorganizing all my Sim to avoid errors... As I can I ll retrydid ya check the Befaco slew limiter simulation?
it follows the input voltage rather than a traditional ADSR or AR envelop that outputs 10 volts from a syntesizer, it does no rise above the input voltage, but you control the rise and fall.
HI Analog thanks for your great explanation! For sure I ll check it better... It s a cool feature seeing in real time how circuit works... Very helpful for a newbie like me... It took me lots of time make Lt works... So I m a bit scared starting a new simulator... But It s an interesting way to run...this one:.
https://tinyurl.com/2yt4tcyq
the one with the audio input.
right click the audio input above the switch on the left in the circuit, select a mp3 on your computer, adjust the "time step" settings to 1m, to set 1 millisecond, otherwise you will grow a beard first before you see the start of the song.
and see the "envelop" ride over the audio by playing the "rise" and "fall" or attack and decay slider in the right column.
You can also see how the "peak" detector from your circuit works in real time, but rather the ATTACK/decay circuit in your circuit, use the fbefaco slew limiter instead. just build it in front of it and move the audio input. and falstad has a better wave rectifier circuit in the examples circuits.
ran Falstad... starting to understand a bit.....
nope,HI Analog thanks for your great explanation! For sure I ll check it better... It s a cool feature seeing in real time how circuit works... Very helpful for a newbie like me... It took me lots of time make Lt works... So I m a bit scared starting a new simulator... But It s an interesting way to run...
So your advice is to put the Befaco slew limiter in front of the detector... Right?
Let s see... I ll keep you updated
Best
Yep, C4 is the timing cap.ran Falstad... starting to understand a bit.....
is there a way to listen to the processing sound?
so according to befaco s schemo the input buffer defines the shape of the detector made by the bjt array...right?
is c4 Timing cap? or both c3 and c4 for charge and discharge?
rise and fall cv out are used to drive external devices?
edit- or rise and fall cv are for external sidechain?
thanks for attention
best
7.2 mm (length) | 4.5 mm (width) | 6 mm (height) | ||
brand: Wima (Germany) | ||||
Series: FKP 2 | ||||
Tolerance: 2.5% | ||||
7.2 mm (length) | 4.5 mm (width) | 6 mm (height) | |||
brand: Wima | |||||
Series: FKP 2 | |||||
Tolerance: 2.5% | |||||
Thanks for clarifying....Yep, C4 is the timing cap.
that's the you might want to adjust in the real circuit to a smaller one, like 1nF or so.
Use Wima AC pulse capacitors or some other high spec with a 2.5% tolerance.
2nF2
https://eu.mouser.com/ProductDetail/WIMA/FKP2C012201D00HSSD?qs=WI052HLiD5jLQ3B/QKmOLQ==size:
7.2 mm (length) 4.5 mm (width) 6 mm (height) brand: Wima (Germany) Series: FKP 2 Tolerance: 2.5%
Dielectric: Polypropylene (PP)
https://eu.mouser.com/ProductDetail/WIMA/FKP2C011001D00HSSD?qs=WI052HLiD5hOMKujMbXT9w==1nF
C3 is to make the circuit stable, use this one
100pF
https://eu.mouser.com/ProductDetail/WIMA/FKP2C001001D00HN00?qs=WI052HLiD5hqsCUy38Lkcw==Film Capacitors
pretty much the best.
7.2 mm (length) 4.5 mm (width) 6 mm (height) brand: Wima Series: FKP 2 Tolerance: 2.5%
pick a PCB footprint that you especially made for easy removal or unsoldering, a special made one with bigger holes so you don't overheat the small via and they come off the PCB and your project is destroyed, like 1.0 mm drill and 2 mm outer diameter or more. best is to use slotted holes using the milling layer in eagle (a topic on it's own) or custom via in Kicad.
Rise and Fall CV are indeed for external gear, you can leave the out if you like, unless you change them to an audio input with wave rectifiers.
