Hi Folks! Alex here, first time poster...
Hopefully I don't insight a riot or something lol.
I searched the forum but couldn't find anything that my feeble brain could translate into a solution for my project...
I'm trying to take the "Battery Powered One Knob Squeezer" from THATCorp (link below), and adapt it in a few ways:
Use the 4315, operate at line level, and use TL072/4 Op Amps...
Again, I apologize in advanced for the noob questions. I'll take all the eye rolls with salt...on the egg shells that I'm already walking on.
I've breadboarded this circuit two separate times, and combed through everything over and over. So I'm hoping you fine folks will spot something. I've been staring at it for days, so I'm bound to miss something, as it often goes.
The op amp that I circled is meant to take the voltage signal, and put out a current signal. It's outputting current, but no signal
However, using an oscilloscope (dc coupling), and putting a 1kHz sine wave @ 1V pp, I'm not seeing anything other than a straight current output...
Could be an amateur measurement fault, but I also get no sound with a test speaker if I poke the signal lines all the way to the end, of course.
Obviously I don't expect you to comb through my (albeit, eye bleeding) schematic, but just if there is anything glaring, please, please god, let me know lol.
Sorry for the aneurysm of a schematic, I can't seem to make it any more visible :/ ...I used Eagle...
Are the TL0xx opamps to blame here? Have I screwed the pooch completely in other ways? Should I recluse?
Thanks all! I hope you're well.
THATCorp Link: http://www.thatcorp.com/pedals/4316 Battery-Powered One Knob Squeezer.pdf
