franklinh
This thead will probably be over in about two replies. However, I've searched quite a bit and not really found the answer. The scenario is:
I'm building a (active) stereo mixer. The panpot is feeding multiple bussing switches (at line level) , about 3.5" between farthest point to hit on switches with signal and panpot lugs, traveling over the first two to get to the last one. There's room to keep the left and right output wires away from one another, and room to "fly" above the back of the switch. Better than an inch between adjacent channels. The whole assembly is out of the way of everything else and on it's own lexan panel. Do I need to use shielded wire from the panpot to the switches? I'm sure I'd find out the hard way if I could listen to it as I went, i'm just at a point in building where knowing would save me a chunk of time and labor either way.
The only example to work from is a y@maha module where they did use shielded wire for this but is was also tightly bundled with other signals.
I'd imagine this is part of why layout is so crucial. Are there minimum distances to be observed? Is crosstalk the big concern here? What year is it?
Frank
Frank
