Ricardus said:When guys order PCBs up here, like for the Bo Hansen DI or these other projects, how many boards do they usually order?
My own experience is mostly a couple.
ruffrecords said:My own experience is mostly a couple.
Ricardus said:Nonono.
I mean the people who stock them.
ruffrecords said:Do you mean how many boards to sellers usually order from the PCB manufacturers?
Ricardus said:Yes. To get the best prices and such.
cpsmusic said:I'm interested in this too although more from a user perspective as opposed to a designer's.
The more I though about the "Volk EQ" the more I thought that the best place to look for inspiration would be a well-thought-out channel strip EQ.
Cheers!
OneRoomStudios said:For maximum flexibility, I think it makes the most sense to make any PCBs mono. If you want stereo, buy two and find the appropriate 2-gang/4-gang pots or switches. It might also make sense to leave pots off-board so that people can use switches if they want, or whatever footprint pots they want. That would make the wiring a little more annoying though. As always, there will have to be some kind of balance between simplicity and flexibility.
I doubt 500 series is in the cards - too many controls for the front panel.
Thoughts?
Ricardus said:The only suggestion I would make would be to make it as future-proof as possible. Choosing components that hopefully won't become obsolete and unobtanium in a short time. (so if we could make it entirely out of 555 timers that would be awesome)
I know that's a difficult guessing game, but just a thought.
OneRoomStudios said:A few things:
Thoughts?
fragletrollet said:Nothing is impossible... 8)
https://www.thomann.de/gb/ssl_xrack_stereo_eq_modul.htm
Sure, no DOA's or TX's, but stereo 4-band in something comparable to to 500 series (width).
abbey road d enfer said:You can't have "stereo parametric EQ" and "future-proof" in the same sentence. 4-stack frequency potentiometers are always custom parts.
Wien-bridge EQ's request RevLog frequency pots, that are also hard to get.
For this reason I favour the SVF EQ/filters that uses law-steered linear taper pots. More than one opamp per stage though.
Fully parametric or semi parametric, you still need dual pots for frequency.OneRoomStudios said:This project is best described as "semi-parametric" at best, since the Q is not adjustable.
Do you really have hands on experience of that? I have and can assure you it's not pleasant, unless you restrict the sweep range to 1:3 or 1:4, which requires switching capacitors for acceptable range.As for the pots, I'll quote Rod Elliot:
"Resistance Vs. Frequency: Ideally, you'd use an antilog pot but unless the taper is really a reverse logarithmic type (very rare and generally considered unobtainable), you are better off with the linear taper. Although it gets a little touchy as you get close to minimum resistance (maximum frequency), linear pots generally have better tracking than log or reverse log, and are far more predictable."
He goes on to present a table of linear pot rotation vs frequency in a Wien Bridge circuit. You can see it here: https://sound-au.com/project150.htm
This is very debatable. The same site shows that for a given rotation of about 15° the variation is +10% on the CCW side and +100% on the CW side: that's for a 1:10 sweep range. Most non-switchable midrange EQ's tend to favour a range of 1:20 or more.In practice, linear does the job just fine,
