Thanks god that somebody experienced that problem. I still don't have my unit finished but it was obvious that "VU" must be some low internal meter (ma meter or ua meter). BTW, I don't think that scoping the waveform is necessarily for checking unit. Just proper supply voltage after meter. I presume that you had a huge voltage drop with few kohm meter so tubes were working with low voltage . Bluebird, can U tell us about your voltage after meter? It will be great to know is somebody experienced same problem as you.I found out I had a meter with a high internal resistance so I ended up replacing R6 (22K) with 100 ohms. If your not using the recommended meter I suggest you check your output on a scope to make sure your not starving your 6BC8 plates.
Hey, that's great pimp! Do you have a time to draw a final combination (values) of your time constants?I still felt like the attack knob wasn't changing the time constant enough.
I glanced over the original 670 schematic and realized it has a resistor in PARALLEL with the time constant caps not in series that changes.
Thanks for drawing BTW, did you tried fairchild values?Heck just use the fairchild values!
Hmm, why Analag went with 10k and 10uF? I wonder
If I understand correctly PM meter works like a DC ma meter since it's connected in series with DC supply. There is no AC voltage. Just DC voltage drop around meter resistance. I think that resistance have to be few Kohms but less can work even better since current is not static because of constant gain change of Valves. I asked few times for DC currents through meter but nobody gave me an answer .I tried removing the resistor inside & put the diodes on them JUST to see how they'd respond as "AC" VU's & the needle hardly moved at all
I think that it should work, I don't see any reason for not... just, c3 have to be changed to 2uF....R18 is not important , I think.. :BUT if we're trying to copy a Fairchild... why not go all the way & use the original time constants & values?
The question is... will it work correctly on the PM version?
"JUST to see how they'd respond as "AC" VU's"
