radiance
lolo-m said:3°) set the pot to -6V, and note the value... and so on...
As in: all the way up till -17V?
I bet you will reach -20 dB way before a grid value of -17V. 6 points from 0 dB to reach -20dB is really enough to match the tubes. More is a pure overkill.radiance said:lolo-m said:3°) set the pot to -6V, and note the value... and so on...
Are you referring to -20db reading of the vu meter in your test circuit?lolo-m said:... reach -20 dB
Yes !jackies said:Are you referring to -20db reading of the vu meter in your test circuit?lolo-m said:... reach -20 dB
Yes, if you use a 5K in your PM670.radiance said:P1 = 20K instead of 5K?
miko said:hello diy'ers
a quick question.
Where can i buy the PCB's for this project.
i've been looking for them but i can't find them.
(i used the SEARCH function :-\)
miko
inputoutput said:Well, I installed LL1676 in a 1:1 configuration at the input and at T3.
PS, how are you even able to wire LL1676 as 1:1?
Enter 6N5P. Out of a batch of 12 there were four perfect matches, all values pretty much equal. With cross matching I can actually use most of the rest of the tubes in the future as well! Incredible tolerances! About a third of them have an odd unstable heater (no 6BC8 has this), and some of them can be heard doing a "shuffling paper near the mic" type of distortion. I'll test if these are simply duds, or if they just need a burn-in.
Headroom is finally there, now in the range of the rest of the studio! And the "roof" of the headroom is very very soft saturation, just wonderful! I've never heard anything like it. This will find a LOT of use. 6N5P is simply a great tube.
Silvas said:What about heaters current draw with the 6n5p ? will be good idea to beef up the power trafo ? i think i´ll order a small lot to play with them on my PM...
