i find almost everything at Banzaieffects.com
search is easyer, less references... it saves a lot lot of time !
sometimes it's a little bit more expensive but... time is money
here my order :
Notice > i didn't double check - maybe mistakes...
when i copy > paste, i loose the numbers (how many) of items.
just copy the first line in search engine > you get to the product !
WIMA MKS2 0,22uF, 63V
MKS2 10%, RM5
€0.18 x = €0.36
WIMA MKS2 0,1uF, 63V 5%
MKS2 5%, RM5
€0.15 x = €0.60
WIMA MKS2 1,5uF, 63V
MKS2 10%, RM5
€0.42 x = €0.84
WIMA MKP4 10uF 250V
MKP4 10uF, 250 VDC/160 VAC, Tolerance: 10%, LS 37,5mm, Size: 19x32x41,5 mm
€5.24 x = €20.96
1N4148-PHI
Silicon Universal Diode, made by NXP Philips
75V 150mA DO35
€0.10 x = €1.00
WIMA MKP4 0,1uF 630V
MKP4 0,1uF, 630 VDC/280 VAC, Tolerance: 10%, LS 15mm, Size: 7x14x18 mm
€0.61 x = €2.44
Panasonic FC 10uF 25V
Panasonic FC electrolytic radial capacitor. Low impedance, long life. Widely acknowledged to be one of the best electrolytic caps available. Black blue body with gold marking.
Dimensions: 4x7mm, LS 1,5mm.
€0.19 x = €0.38
Panasonic FC 100uF 25V
Dimensions: 6,3x11,2mm, LS 2,5mm.
€0.24 x = €0.48
Panasonic FC 1000uF 25V
Dimensions: 12,5x20,0mm, LS 5,0mm.
€0.94 x = €3.76
Panasonic FC 4700uF 16V
Dimensions: 18,0x25,0mm, LS 7,5mm.
€2.98 x = €5.96
including VAT 19% (€0.95)
Roederstein EKA 47uF 350V
Vishay Roederstein EKO electrolytic radial capacitor. High switching capability, polarized, isolated.
Dimensions: 16x25mm, LS 7,5mm.
€1.79 x = €1.79
100uF, 350V Radial
Electrolytic Radial 18x40mm, RM7,5
€2.74 x = €8.22
1N4007
Silicon Diode, 1000V 1A, DO41
€0.06 x = €0.96
MPSA42
NPN 300V 0,5A 0,625W B>25 TO92
€0.12 x = €0.24
MPSA92
PNP 300V 0,5A 0,625W B>25 TO92
€0.12 x = €0.12
IRF820
N-MOS 500V 2,5A 50W 3,0R TO220AB
€0.71 x = €0.71
IRF840
N-MOS 500V 8A 125W 0,85R TO220AB
€0.90 x = €0.90
LM317T
LM317 T
Voltage Regulator 1,2V - 37V, 1,5A TO220
€0.31 x = €0.31
Heat Sink SHS104-38ST-SCREW
Heatsink for all semiconductors in TO220, SOT32- and TOP3 package. 38,1mm. Vertical mount using included solder terminals (Ø 2,3mm). Semiconductor attachable using M3 screws (through hole without threading). Black anodized. RthK: 11 K/W.
€1.31 x = €2.62
Heat Sink SHS104-51ST-SCREW
Heatsink for all semiconductors in TO220, SOT32- and TOP3 package. 50,8mm. Vertical mount using included solder terminals (Ø 2,3mm). Semiconductor attachable using M3 screws (through hole without threading). Black anodized. RthK: 9 K/W.
€1.43 x = €2.86
Heat Sink SHS104-25ST-SCREW
Heatsink for all semiconductors in TO220, SOT32- and TOP3 package. 25,4mm. Vertical mount using included solder terminals (Ø 2,3mm). Semiconductor attachable using M3 screws (through hole without threading). Black anodized. RthK: 14 K/W.
€1.31 x = €2.62
220uF, 400V Radial
Electrolytic Radial 25x40mm, LS10
€4.97 x = €9.94
Trimpot T93-YB 4,7k
VISHAY Precision Trimpot, vertical, multiturn, cermet, 1/2W 4,7k
Dimensions: 9,7x4,8mm. Leg spacing: 5,08/2,54mm
€0.71 x = €4.26
2N6107
2N6107 Transistor PNP 70V 7A 40W TO220
€0.82 x = €1.64
i took the resistors and the few things remainning at farnell.
