Handcrafted Tone
I can't believe this has happening... I think I ... nooooo!!!! ... I think I'm becoming a PC guy. DAMN YOU GATES!
My job bought me a new PC laptop. I still love my Mac G5 as a rock solid PT system, but I haven't used it for anything else in a month. Eagle runs slightly smoother, office suite is sweet, and I came across a stellar FREE audio measurement program called RightMark.
I measured a twin-servo preamp I built and the frequency response seemed pretty bad. This twin was ridiculous to start with, it had two fabio 2520 DOAs and a API2503 output transformer. In a design that is supposed to be clean, I used very colored components. I decided to run RightMark directly through the 2503 and found the culprit. If the color is in the iron, the 2053 has plenty of it.
DISCLAIMER - Unfortunately there's no firewire port on this PC. I haven't found a USB device with good converters, so I borrowed a crappy M-Audio Quattro from a friend. I included a direct loop of the converters as a base line to compare to.
That said, check out the frequency response of the transformers I had on my bench. We've got a 2503, a Cinemag CMOB-2S, and CMOB-2n.
http://www.handcraftedtone.com/xfer/RightMark/Comparison.htm
The picture I included is extremely exaggerated (there is only 1-2db of total frequency deviation in the 2503), but you get the idea.
Looks like the CMOB-2S isn't really that close to the 2503...
I've also measured a few mic input transformers. We should start a RightMark thread and share our results. I'll wait until I get a good :roll: USB interface.
