This power supply for api 312
Coldsnow
Ohio
Hi, I have an Aphex 106 compressor that I don't use.  The pots are bad etc.  so anyways, can I use the power supply 24 vac adaptor type converted to plus and minus 15 volts.  Will it be enough power for 1 or 2 discrete opamps?
    870.4 KB
thru the miracles of modern science we were able to re-process that jpg,  :D
should be plenty of juice,  Natl Semi, good stuff,
do you need a couple of output transformers for this project?
    146.1 KB
