> my suggestion of joining R14 and R16? 20 dB more CMRR is always handy, especially if it even saves one part, improves DC offset and shouldn't have any sonic side effects.
Agree. With that change, I would not worry about output offset. I would however like to see 100Ω output resistors for long-line stability, and perhaps a place for Phantom input caps.
R17 is pointless. Change R1 R2 R18 R19 to 90Ω and the max gain is the same, noise the same, DC match triflingly better, and we save a part.
Distortion on large outputs may not be point-oh-oh-oh stuff but should be small and inoffensive.
Noise on passive (dynamic and ribbon) mikes is not theoretically low, but close enough that it is a non-issue unless you record harpsichord in Iceland.
I would prefer BIG parts in the input. TO92 transistors and 1/4W-1/2W LEG resistors. There is some component of resistor noise that is inversely related to size. When you have 10 zillion carbon atoms, you don't hear each one vibrate; when you have only a zillion atoms you start to hear their individual random agitation. This was not an issue until these teeny-weeny SMD parts came along. If you don't like drilling boards, put down 6mm square copper pads and butt-solder the resistors. I wouldn't go on truck-tour with the Rollin Stones that way, but I do slam butt-soldered PCB amps in/out of bags on my gigs.
