TL Audio Ivory2 5001 input preamps?
Jitter
Spain
Hi!
I’ve a unit of TL Audio Ivory2 5001 (discrete transistor preamp version) and I wanna know if is possible to add an input transformer in each channel to mod the preamps.
I’ve 4 OEP A262A3E for this purpose.
    168.4 KB
    245.3 KB
Your transformers have a quite high turns ratio, so it would add a lot of gain to the circuit. With strong signals, you might get clipping even with the pad on. (But you can increase the attenuation of the pad by using a lower value for R157)
Anyways, the transformer should go after the pad, instead of C164 and C144 (but maybe check that the voltage across C151 (between the differential inputs of the amplifier) is very small, or else you might have excessive DC current going through the transformer windings, in which case you want to keep C164 and C144 and put the transformer right before those.)
If, once the transformer is installed, you have a bump boosting your low-end, you will need to increase the value of C5 and C17. With the extra inductance from the transformer, C197 and C202 might cut some highs out, so you want to watch for that too.
Thanks for your reply.
I understand the OEP A262A3E “problems”, but if the trx will be a 1:1 relation as OEP A262A7E…
The position in the circuit will be after PAD or before?
    224.8 KB
