TL783 & psu design
daArry
londaaan
Hey,
Does this vreg behave the same way as the LM317 with regards to output voltage? So say I need around 100VDC regulated from recified 120VAC would I use 470R for R1 and 39K for R2 for the TL adjustment resistors?
Cheers!
Hi:
No, you must use another formulae.
This is a link for the TL783 datasheet:
http://focus.ti.com/lit/ds/symlink/tl783.pdf
As you can see the recommended resistor from the out pin to Adjust pin(R1) must be around 82 ohms to maintain a minimum load current and the formula to calculate output V is:Vout=1.25Vx(1+(R2/R1))(aprox.)so to obtain R2 value from desired Out V we have: R2=R1x((Vout-1.25)/1.25) if your desired Vout is 100V the value for R2 would be around 6k47 ohms.
Camel
Cheers Camel,
Here's the psu ckt it's used in:
The TL bit is based on the G9 supply which I thought be coo to use as I have some TL783's in. I guess I don't need all 3 of those ZD39's there tho - just 1 ok?
Thanks again :thumb:
[quote author="daArry"]Cheers Camel,
I guess I don't need all 3 of those ZD39's there tho - just 1 ok?[/quote]
120VAC yield about 165V of rectified DC. You need the three zeners (or 1 120V zener).
Peace,
Al.
Hey,
Just to clear up...
The 2 470R/2W resistors (R7, R12) - are these needed in this psu? I drew them in based on the G9 supply which delivers much higher voltage out on the TL783 - 245V instead of the 100V needed here...
Also, are those transformers connected okay and is the way a single ground has been used been implemented correctly?
Just need to put my mind at rest - spent ages trying to get a psu sorted for prrs' vari-mu comp ere!!
wellll ok then, thanks for putting my mind at rest...
anyway, transformers are hooked up and nothing exploded so far - verobrd'ed the +/-15, +12 and 1.5V supplies so it's just the 100v big spuds to go....
I'm right in thinking i can omit those 2 resistors i mentioned prior tho right? They act as to lower voltage ye and so are not needed in this instance...?
[quote author="daArry"]I'm right in thinking i can omit those 2 resistors i mentioned prior tho right? They act as to lower voltage ye and so are not needed in this instance...?[/quote]
I don't think so... It looks to me like they limit the current, not the voltage. Jakob will know better, I'm sure...
Peace,
Al.
Yeah, looking at the schematic I'm pretty sure they're there to protect the zeners at turn on...
Peace,
Al.
much obliged al - thanks again :thumb:
nuttin but stress with this fokkin thing tho, hooked up the tranformers as I said and when measured for AC - all good, gettin 113VAC for the 110 outs and 17ishVAC for the 15V outputs...however...
I made a simple diode bridge with 4x 1N4006's for the 110VAC so I could get a ground ref to make sure the +12,15,-15 ckt i made on breadboard was working. I only get like 106VDC with the rectifier :/ and with the +12,15,-15 ckt added to the 15VAC, the 12V is fine but the -15 is only giving out like -8V, the +15 Im not sure yet as I don't have one of those vregs to hand...
Here's the hookup for the **** i've tested so far...def okay ye?
Also noticed a slight buzz coming from the transformers - that normal for the box type ones?
A buzz on your transformer and the low voltage indicate a problem. Could be miss wired ground on the rectifier or a phase problem on the transformer winding. Chaeck it again before you hook it up. I just quickly fried a small transformer with a missplaced ground on the rectifier.
Hey,
I dunno :roll:
I've checked it over n over - even with nothing connected to the tx's (but both joined together as in pic above) theres still a lil buzz...
