Toft ATB 32 ch blues
I was thinking DPS 200 not CPS 200. The CPS 275 Looks like a good option.
I also found DDA PSI 2860. That has the +-17v/6A and 48v .35A. Also seems to have the ground and number of wires. There is a 6th wire for “switched output relays” that doesn’t seem to be needed on the ATB24. I guess I’d disconnect that on the inside of the box.
Then can just change the connector and make sure the pins are in the right place.
….then sell the beast ;-)
