bluebird
So I took my new Philbrick preamp down to the studio and did what I always do, compare it to my 1272's and G9. I record drums and compare on different mics and different positions. I check out noise and high and lows.
One problem I always seem to have is too much gain. This is not a problem with the Neve 1272's or the G9. The 1272's don't have a pad and I've never had to use the ones on the G9. I know its not the input transformer because I'm using the same one in the G9 that I'm using in the other pres.
On both the langevin and the philbrick pres I overload the input not only with dynamics on kick and snare but also with a large diaphram condenser 8 feet away from the drum kit. Things are fine when I engage the pads but the noise floor goes way up.
on another post Dave (soundguy) said he uses pads on almost everything when tracking. I'm assuming he's talking about recording loud rock like me. So this might not be so out of the ordinary.
But why can the Neve take such a loud signal why the simpler circuits like the Langevin and the API similar Philbrick can't?
I have noticed on the API/Philbrick circuit there is a set resistor (20K) in the feedback loop. gain is manipulated with variable resistance into a large cap to ground. would manipulating this feedback resistance (20k) bring the gain down without messing with the frequency response?
By the way, heres the API schematic I used:
http://www.waltzingbear.com/Schematics/API/API_312.htm
Thoughts comments????
