Just opening the gate and leaving it floating could cause odd behavior from stray leakage.valco said:I´ve got this Tore seem preamp build for the Norwegian broadcasting Company and its got a built in limiter that i want to deactivate . It´s supposed to be the Q1 in the second schematic. Do i unsolder the "g" leg to deactivate the output limiter ?
JohnRoberts said:Just opening the gate and leaving it floating could cause odd behavior from stray leakage.
I might suggest lifting the diode(s) feeding the control voltage, so it will behave as if there is no signal and cut off the JFET.
You have two different schematics, a simpler remedy is to lift the drain lead. That should take the JFET out of the audio path.valco said:Thanks !
So you mean D1 ?
As JR already said, unsoldering the "d" leg would deactivate it. Or just remove the transistor entirely if that's easier.valco said:I´ve got this Tore seem preamp build for the Norwegian broadcasting Company and its got a built in limiter that i want to deactivate . It´s supposed to be the Q1 in the second schematic. Do i unsolder the "g" leg to deactivate the output limiter ?
Amplifier A1 in the limiter has a gain of of 62 times which is nearly 36dB. I expect under normal operation R1 and the FET form an attenuator which significantly reduces the overall gain. When you disconnect the FET the gain jumps up to 36dB so the headroom will certainly be compromised. If you are going to remove the limiter function then you probably need to replace the FET with a suitable resistor to bring the overall gain down to a sensible figues. What that figure should be is difficult to say because it depends on the gain of the mic pre stage that precedes it. If you have the schematic of that we could give you a better answer.They probably originate from the Norwegian Broadcast company, but I'm just trying to get them usable.
Do you mean VU-meter or Gain-reduction meter?is it possible to attach a VU meter
Hi ErikDo you mean VU-meter or Gain-reduction meter?
looks really nice -I have six of these, and none of them have an LED-indikator.
/Erik
