sethinspain
Active member
- Joined
- Dec 18, 2011
- Messages
- 36
Hey everyone,
In the middle of a DIY pre (green pre ::thumbs up:: ) and I'm testing voltages with my 15-0-15 trafo to make sure the PSU is ready to plug into the pre.
I have been testing it for a bit working with the voltages for a couple weeks when suddenly, as of last night, I switch it on and I read 0 volts across the secondary pins.
Across the primary pins I read 227v (Spain) like I should, but secondaries read 0. I tested continuity between the secondary pins (3 & 4, 1 & 2) and I read 0 ohms, so I don't think the trafo is busted. I've got the mains running through a switch to a fuse before the trafo - switched out the fuse just for good measure. I have NO idea what to do.
The trafo works but reads no volts, yet I read input voltage on the primary side, what gives?!
Any help would be much appreciated. So close yet so far.... :-\
Seth
:: EDIT ::
Tested secondary voltages on pins 5 & 6, 7 & 8. Primaries are pins 1 & 2, 3 & 4. Link to trafo and datasheet are here as well as 2 posts down:
http://www.mouser.com/ProductDetail/Triad-Magnetics/FP30-400/?qs=71qcunE5gONSODXqnt1RVw%3d%3d
Seth
:: EDIT ::
