ruffrecords said:...as long as you drive them from a fairly low impedance they will work fine.
Samuel Groner said:You don't need a transformer to balance an output, a resistor is basically enough. See page 3, top left of this document: www.jensen-transformers.com/an/an003.pdf
Samuel
RuudNL said:I always try to drive an output transformer from a (almost) zero ohms impedance.
Samuel
ilfungo said:Q39=2N2905
Q40=2N2219A
Cheap xfmr will get you cheap performance.ilfungo said:Hi
I'm searching a good and cheapaudio transformer for balance the direct out of my mixer...
Suggestions?
Thanks!!!
cheap because I need 32 of them...![]()
ilfungo said:Thanks ruffrecords!!!
Just the last info
do you think I need a zobel network on secondary for this configuration?
I recall those from the '60s The 2n2905 is the t0-5 higher power dissipation version of the 2n2907 (GP PNP), and the 2n2219 is the similar higher power version of the 2n2222 (NPN).ruffrecords said:ilfungo said:Q39=2N2905
Q40=2N2219A
I checked out the data sheet for the 2N2905 and it looks like a typical low power type. I expect it would have no trouble in a class B stage in driving a 600 ohm load. So, it looks like the 600:600 Carnhill should be OK.
ruffrecords said:RuudNL said:I always try to drive an output transformer from a (almost) zero ohms impedance.
You have to be carful with that if there is a series capacitor involved. The capacitor and the primary inductance of the transformer form a resonant circuit which will have a peak at some (hopefully) sub-sonic frequency. The amplitude and sharpness of that peak depends on the Q of the resonant circuit which in turn depends on the series resistance of the circuit. The series resistance usually has two components; the transformer primary dc resistance and the source impedance of the driving amplifier.
