zamproject
- Joined
- May 11, 2010
- Messages
- 1,630
yep...don't tell me...i can also load a great dish of those
IM is more relevant than THD. Global feedback could be minimized with local degeneration, in cathode, emitter, or source, leave bypass cap out.My younger experienced ears tell me high NFB ckts suppress low level info, reverb tails, room tone, etc. That may be due to the suppression of harmonics mentioned, I don't know. IMHO, distortion down to .0001% from the use of NFB is a rabbit hole.
I don't know why you edited out this part of your post; "Do classic circuits not do that because they wanted transformer distortion, or because they didn't think it was necessary because the transformers were sufficiently linear, or what?", but I have an answer: Yes (particularly "or what?").![]()
When a xfmr is grafted onto an existing design, there is almost no other choice than using the best possible xfmr there, according to the drive capability of the output stage, size and budget constraints.Say What?
A whole lot of Asberger's has infested this thread, as with so many threads in Group DIY.
IIRC Otala was trying to push his newly invented form of distortion he called TIM (transient intermodulation distortion). Around the same time (70s?) there was another wannabe distortion SID (slew induced distortion). The common theme for these was slew rate limiting and perturbations caused when NFB circuits recover poorly from slew overload events.Matti Otala was the guy that said global NFB could not work because the NFB signal would come too late. It's the same train of thought as the Zenon of Elea paradox, which claimed that the arrow could never attain the turtle. It's been debunked a long time ago.
Is there usually a need for a custom transformer? I'd think there'd be fine stock transformers with tertiaries, and that the exact ratio of the tertiary wouldn't be critical because you could compensate in the circuit's resistors or whatever that determine how the input is scaled down for use as feedback.When implementing a xfmr into a new design, unless a custom xfmr is not permitted, there is no pragmatic reason to not use a tertiary winding. The technique is well-known (after all, the Williamson amplifier dates back from 1947). Compared to the Williamson amplifier, the tertiary winding still permits the secondary to be fully floating.
In many cases, probably not. However, when I started working on my output stage, there was not much choice of affordable xfmrs. I coud have based my work on Haufe, Sowter or Lundahl, but the cost was prohibitive.Is there usually a need for a custom transformer?
