sr1200
I've looked on the site, and have researched elsewhere but I still cant find anything that really explains what the frequency response for a transformer is.
From what wikipedia states...
To me this seems more aimed at the utility frequency (50-60hz in the US)
I guess my question more relates to how this relates to frequency response in audio.
When selecting a transformer for say a balanced line input, does the transformers frequency response have anything to do with the way it will handle the incoming frequencies?
Sorry for the nubblyness and hopefully I put this in the right forum this time... :-[
reason why im asking:
Im looking for something VERY small (smaller than a carnhill) to turn a balanced signal unbalanced.
Operation of a transformer at its designed voltage but at a higher frequency than intended will lead to reduced magnetizing current; at lower frequency, the magnetizing current will increase. Operation of a transformer at other than its design frequency may require assessment of voltages, losses, and cooling to establish if safe operation is practical. For example, transformers may need to be equipped with "volts per hertz" over-excitation relays to protect the transformer from overvoltage at higher than rated frequency.
