tablebeast
I was asked this question the other day and I wasn't sure about the answer so I am bringing it to you guys to decipher. OK, so if I have a tube amp that has multiple taps on its output transformer can I hook up to more than one tap at a time? If I do hook up to say an 8 ohm tap and a 16 ohm tap at the same time how do the two connections affect each other as far as load impedance and/or power output?
Jesse
Jesse
