edanderson
first posted this list back on "the old place" in 2003 ish era. now with more info added; some may be out of date, use at your own risk. reply with any updates if you want them added.
ed
shops that support the forum
classic audio products of illinois
http://www.classicapi.com/catalog/
input and output transformers for api type projects
hairball audio
http://www.hairballaudio.com/shop/
input and output transformers for 1176 and neve type projects
samar audio design
http://www.samaraudiodesign.com/Products.html
a range of line, mic, and ribbon transformers
51x audio
http://www.groupdiy.com/index.php?topic=39570.0
volker sells haufe ST8456 mic input transformers in his shop
pro audio standard parts
you should be able to order most of these easily from stock
jensen transformers, inc - usa
http://www.jensen-transformers.com
(866) 476-6291
very good, clean sounding, industry standard
lots of info, application notes, etc. on webpage
expensive, but you get what you pay for
(not to be confused with jensen electronics, no relation)
hammond - canada / usa
http://www.hammondmfg.com/5caud.htm
a good selection and good product, available through digikey, mouser, etc
relatively expensive
lundahl - sweden
www.lundahl.se
see site for distributors
an expanding selection of very high quality units
one or two vintage repro units - rca bc-2b
may do custom design with enough demand
used in a number of gyraf designs!
generally very transparent
sowter - uk
http://www.sowter.co.uk
good quality, some vintage repro units (incl neve)
will sometimes do custom designs, have their own style
will sell single units direct
also available through
stevens and billington - uk
http://www.stevens-billington.co.uk/
make a range of mu-shielded line in and out and mic in transformers
individuals can buy direct
crimson audio transformers - usa
http://www.crimsonaudiotransformers.com
make a 1:1 line input, 1:10 mic input and a 4:1 output
can do custom designs
jlm audio - australia
http://www.jlmaudio.com
makes a toroid 1:10 input and an api 2503 like output, gapped neve-esque output
cinemag - usa
http://www.cinemag.biz
make transformers for many pro audio shops
experience electronics - germany
http://www.experience-electronics.de/englisch/bauteile/studio-uebertrager.htm
a range of mic input and 1:1 line in and out transformers
lynx audio - brazil (thanks fabio)
http://www.audiolink.com.br/audiolink/transformadores/audio.htm
small range of line in and out transformers
harbuch - australia
http://www.harbuch.com.au
kev has used these and likes them
full line of input, output and power transformers
they are have some inexpensive units if you're in this part of the world
neutrik - liechtenstein (fun to say)
http://www.neutrik.com
look under products > accessories > transformers
they make a few mu-metal shielded units
which look similar to lundahls
and some really tiny non shielded ones
ask your local neutrik rep, can be hard to get or expensive
beyer dynamic - germany
http://home.hetnet.nl/mr_7/66/chickennerdpig/FILES/BeyerDynamic_AudioInputTransformers_catalog.pdf
they make a line of physically tiny transformers
mostly mic and line input
not too expensive but minimum orders may apply
contact your local beyer rep
amplimo - netherlands
http://www.ringkerntrafo.nl/category.php?id_category=40
make some very affordable small 1:1 and stepup transformers
and some more robust ones that cost more
bürklin - germany
http://www.buerklin.com/
some inexpensive iso and mic input transformers made by pikatron
and some high quality toroid input and output transformers
usa office: (970) 429-1265
audio 1:1 iso - C105.900
mic input - C106.000
high quality 1:1 input - C106.100
high quality 1:1 output - C106.400
pikatron - germany
http://www.pikatron.de/en/home.html
jakob mentioned they still make replacement
trafos for the old neumann preamp modules
they also make an inexpensive 1:10 mic input
usually have a minimum order, but they do sell direct
oep - uk
http://www.oep.co.uk
make a limited but versatile selection
sold thru farnell- newark can order them in the usa
sell seperate mumetal shield cans.
inexpensive but good when you want to hear the transformer working
edcor - usa
http://www.edcorusa.com/
somewhat large physically, unshielded
used by several projects on the forum
can do custom work
very inexpensive
monacor - germany
electronic parts vendor sells two inexpensive transformers
very small and colorful 1:1+0.5 line transformer:
http://www.monacor.de/produktdetailseite/?artikelid=2651
DI box transformer 10:1:
http://www.monacor.de/produktdetailseite/?artikelid=6231
available through local resellers in germany
radio shack - usa
this item has two decent 1:1 line transformers inside for $18, p/n 270-054:
http://www.radioshack.com/product/index.jsp?productId=2062214
it sounds terrible, but maybe that's what you want; $3, p/n 273-1380:
http://www.radioshack.com/product/index.jsp?productId=2103254
reproductions of defunct manufacturers
carnhill - uk
www.carnhill.co.uk
making vintage neve repro units
they bought out st ives, who did make neve trannys
BUT marinair made all of the classic ones,
and so the claim of "original" sounding trannys is in dispute.
will sometimes do custom designs.
good quality. expensive and often difficult to deal with.
carnhill has minimum orders.
single units are available for purchase worldwide through:
http://www.audiomaintenance.com/acatalog/index.html
tab-funkenwerk - usa
http://www.tab-funkenwerk.com/x-former.html
oliver archut is the expert on all things telefunken related
offers mic output transformers and V7x series replacement iron
shinrock - germany
http://www.shinrock.de
some very nice info on telefunken gear
mostly custom designs, telefunken and amp repro
haufe - germany
http://www.haufe-uebertrager.de
i'm pretty sure they made many of the trafos
in the old telefunken v-series preamps
not much info on the site
apparently they sell a small T14/1 (AKG C-12 output)
and some of the v-series chokes are available
they will do custom work
utc - usa
was bought out by opt industries
now owned by magnetika aka torwico
http://www.magnetika.com
they claim to be able to make all the old stuff
but you have to order a lot
and their prices change seemingly randomly
good luck
triad - usa
http://www.parallaxpower.com/Catalog/catalog.html
now a part of magnetek, renamed parallax
they used to make a wide range of audio trannys
now just telephone stuff mostly
tho they do say they could do custom work
magnequest - usa
http://www.magnequest.com
owner of all the peerless and acrosound docs
mostly amp output trafos and chokes, hifi stuff
they do make a b7 15k that can be reversed for a 1:5 stepup
have made S-217-D (pultec OPT) in the past for $300ea
hit or miss in terms of getting any response
avon magnetics - uk
http://www.avonmagnetics.co.uk/
do custom audio transformers
have docs for all the old gardners designs
but their repros are VERY expensive
botique hifi vendors
that make some transformers of interest
electra-print - usa
http://www.electra-print.com/lineoutput.html
make a few custom and one 600:15k stepup
as well as one 8:1 output stepdown
shielding costs extra
majestic - uk
http://www.transformers.uk.com/product01.htm
custom only, but do vintage hifi repro
mostly output, power, and chokes
bartolucci - italy
http://www.audiomarketing.net/bartolucci
tube preamp, amplifier, and power transformers
tamura - japan / global
http://www.tamura-ss.co.jp/en/electronics/trance.html#09
tube hifi interstage and output
http://www.tamura-ss.co.jp/en/electronics/trance.html#04
general input and output transformers
no idea if these are actually available
guitar amp transformers
O/netics - usa
http://www.rhodesamplification.com/products/transformers
this site sells their guitar amp transformers
O/netics has done custom pro audio stuff in the past
heyboer - usa
http://heyboertransformers.com/tubeamps.shtml
they make their guitar amp transformers
can do custom work
http://www.mojotone.com/transformers
this site sells heyboer's stock guitar amp transformers
mercury magnetics - usa
http://www.mercurymagnetics.com/pages/mainframe.htm
b2b contacts
these companies don't sell to end users, but may make large quantities of audio transformers
contact them for custom designs
altran - usa
http://www.altrancorp.com/
make a wide range of audio input and output transformers
a few stock parts but mostly custom designs
v&f transformers - usa
http://www.vf-transformer.com/
EI output transformers
woodward schumacher - usa
http://www.schumachercorp.com
known for their guitar amp outputs
they do custom work
marvel magnetics / magnetic components - usa
http://www.marvelelectric.com
http://www.magneticcomponents.net
sister companies known for their guitar amp outputs and EI power transformers
toroidal power transformers
amveco / talema - usa
http://www.amveco.com
pcb mount encapsulated
and chassis mount
available from:
http://www.digikey.com
antrim - uk
http://www.trans-tronic.co.uk/
avel lindberg - usa
http://www.avellindberg.com/
a good standard line of toroids
plitron - canada
http://www.plitron.com
also do pricey hifi tube output transformers
powertronix - usa
http://www.powertronix.com/
they make a line of audio power supply toroids
toroid corp of maryland - usa
http://www.toroid.com
205-5076 is a tube preamp power transformer for $91
their standard line is on the pricey side
probably defunct
sescom - usa
http://www.sescom.com/
used to make pro audio transformers, no longer on their website
victoria magnetics - usa
http://www.victoriamagnetics.com
website gone, noone can contact the owner
reichenbach - usa
no website, no answer on the phone
hand wound transformers - usa
apparently not trustworthy
profile electronics - usa
website is busted, not sure what happened
ed
hairball audio
samar audio design
51x audio
(866) 476-6291
lundahl - sweden
www.lundahl.se
sowter - uk
cinemag - usa
harbuch - australia
bürklin - germany
pikatron - germany
oep - uk
edcor - usa
can do custom work
very inexpensive
monacor - germany
radio shack - usa
carnhill - uk
www.carnhill.co.uk
shinrock - germany
haufe - germany
utc - usa
good luck
triad - usa
magnequest - usa
avon magnetics - uk
electra-print - usa
majestic - uk
bartolucci - italy
O/netics - usa
heyboer - usa
can do custom work
b2b contacts
altran - usa
they do custom work
and chassis mount
available from:
antrim - uk
avel lindberg - usa
plitron - canada
powertronix - usa
probably defunct
sescom - usa
reichenbach - usa
