Samuel Groner
Unless we're looking at different schematics R10 and R11 are collector loads. The schematic you linked too also provides input device current from the feedback resistors but in your link the input devices are biased -5 V or so. This schematic looks like inputs are biased at 0V so opamp output will need to sit at negative voltage to make required current.
If DC coupling to the opamps is (as usually) employed bias of the input pair is established by setting the collector current, not emitter current. This is because global feedback forces the - input of the opamp to the same potential as the + input, and the latter is fixed at a couple of volts below one of the supply rails. The collector current of the input pair is then given by I = U/R.
The -5.1 V bias in my schematic or some sort of CCS to the emitter (as typically used in mic preamp ICs) helps to center the DC output voltage around ~0 V for best output swing, but does not alter the quiescent current in the input pairs.
Samuel
