I present my idea of a Fet/Tube Input mic pre, this should be quieter than the one I'm presently using. I hope to slap it together on a breadboard soon and disclose what fixes were necessary to get that sound we like to hear.
Analag
Yes, the gain is a bit clumsy in the original version. I don't know what Marik did, I thought he used a pot somewhere.it would probably make a fine mic pre if you needed tons of gain.
That'd be a nice application. Have been thinking about using both those balanced inputs (I have 2 of such boxes) for Fender-Jazz-PU's, pre-blend - but that's a bit too much of non-standard wiring - where that bass goes those 122's won't always be.Or you could use it as-is for a DI.
http://home.hetnet.nl/~chickennerdpig/ FILES/Tek122/Tek_Type122_circuit_ampsection_rt.jpg
Also as mentioned the C45 samples I looked at had a nasty microphonic ringing with a mechanical Q of about 3000 at around 9kHz. Peter Qvortrup of Audio Note remarked to a friend that they sounded "metallic" so maybe he was hearing the ringing.
Yeow!
Man, are they using low current operating points for the front-end stages.
I calculated that Q from the decay of the oscillation envelope after tapping the tube. It was brutal ;-).
I guess it's something apart from (unrelated to) the 10M Rg, correct ?
