leigh
Hi y'all,
I've got a Harmon Kardon ME 40 (mini tube pa) that I'm trying to clean up. There's no documentation, either in my hands nor on the web (afaik). It's a simple scheme, 2 mic ins, 2 aux ins, mix to a single channel for the power stage and output.
Last night I traced one of the mic input circuits. The path does not have an input transformer, which of course is pretty unusual these days for a tube pre. But it was most likely designed for high impedance mics (the mic connectors are center-pin screw-on Amphenols), which wouldn't mind so much going direct to a tube (right?).
The thing is really noisy, and recapping the power supply is definitely in the plans.
But I'm wondering what I might do to make the inputs more friendly to modern mics, besides stick a transformer on there. The input path goes:
in -> 0.1 uF cap -> pin 2 of a 12AX7, with a 3M3 resistor to ground between the cap and the tube
I know this is a very open ended question, but I couldn't find any practical info about using a tube input stage without a transformer.
Cheers and welcome to the (new) jungle,
Leigh
Leigh
