we use a smps PSU so no 100Hz to filter here.
Don't bet on it. There tends to be a fair bit.
And the current consumption is quiet low (would say not more than 100mA / 48v for 2 channels so...)
I stated it in the text, 48V/40mA Channel including Phantom Power (assuming a pull-down to 12V by the Mic).
The "theory" is 160.000uF per Ω serie for -3dB at 1Hz (without consedering high current consumption)
Thor put 10.000uF just after the PSU so it only needs 16Ω for a good RC filter.
I specified an Inductor, Abracon which is 9 Ohm DCR, 1mH. Together with a 10,000uF/10mOhm ESR Electrolytic cap it should kill a lot of noise.
As visible, at the typical 67kHz switching frequency we get > 90dB attenuation, at 100Hz we 35dB attenuation. The ripple at 67kHz at rated current is often as high as 100mV P-P while the 100Hz component can often be as high as 10mV P-P.
After that, 2,2kΩ + 100uF per stage is more than needed (160mF/2200Ω) = 72uF
No, it is fine. Here the cascaded Filtering:
If I follow the "10-times-rule" with an HT PSU feeding anodes that need 10mA under 300v (for ex.) : we don't want to rise in impedance, so we fix 320Ω > (160mF/320Ω)*10 = 5000uF !
Never seen such value in any tube preamp PSU...
The current in the first stage is 0.5mA and in the second stage 2.5mA including ~0.35mA for the Loading resistors.
Also, due to the nature of the active circuit (Virtual inductor) it is not very sensitive to PSU Impedance.
I dont intend to criticize your work, but why all these pads ? do we really need all of them ? it complicates the circuit...
I stated that these are options.
A lot depends on context and use. I personally like good control over things like overload margins, noise and gain.
We could have a -20dB switch pad at input as you previously drew (15KΩ in serie with 33KΩ fixed to ground) in case of the source is too high and then keep the 10KΩ log pot (I have some in stock) and that's all folks.
All up to you.
I search simplicity. The less components the better it sounds (I think so).
Up to a point - yes.
I gave you a simple circuit meant for your specific state requirements in post # 58, this:
You can use the -20dB Pad only.
I then proceeded to extend the design with Output Transformer and more specifics on how I PERSONALLY would implement this, in case someone else is interested to make a more flexible and slightly more complex stand alone version, that drops in for any old mic pre and dos not break the bank with expensive components.
Hence polarity, a 30dB range stepped attenuator in 3dB for fine gain and a 40dB Attenuation in 10dB steps.
It should be possible to balance things like intentional input overload vs output well (this assumes an ADC with ~+20dBm for 0dBFS).
I come back on the Tr In secondary "R impedance set" : the Tr is a 1:9 and with 33KΩ at secondary, the primary "sees only" 33KΩ/81 = 400Ω (?) or I miss something...
Well, I use 47k.
I generally put 220KΩ ~ 300KΩ on my tube pre's for the mics to see 10 times their own impedance (generally 200Ω)
Using the OEP transformer you specify this likely leads to HF peaks. It is designed and specified for 12k....47k load. The very limited primary inductance and seemingly high parasitic capacitance means that even with a 47k load we approach 600 Ohm only in the midrange, at 20Hz and 15kHz it has dropped to 500 Ohm.
Maybe a simpler option for pads is one DPDT switch to take the first gain stage out of circuit and connect the transformer secondary straight to the gain pot (better make it 50K again). The maximum input level is limited only by the transformer then.
Yes, this is an option. I'm a little pernickety about polarity, if doing this the transformer secondary should be inverted.
One minor point: the phantom power switch could be the other side of the 1K resistor. As shown it will short out C9 (100u charged to 48V) if you turn it off when the circuit is powered.
Yes, it was my intention to have a hard short, it makes not much difference.
Here something for the "big" design that incorporates your suggestions. I added one more Gain step as jut Lo/Hi feels a bit of a big gap. A Lorlin Rotary could be used, or two toggles.
A 50KΩ pot could introduce noise : I prefer a -20dB pad by switch at input + 10KΩ pot interstage if you don't mind
I ran this, for 0dBm (.775V) out with Output Transformer without transformer) the simulator suggests 85dB SNR, which is fine.
If the output transformer is omitted and the gain should be at 60dB max. then change as follows:
Thor
