transformers for passive eq
mich
Israel
Im planning on building the gyraf pultec but without the output stage,
so i can plug it into different mic preamps that i have.
(like newyork dave's passive eq) :thumb:
been wondering about the txformers i should use.
im guessing a 600/600 for the input,and somthing like 10K/600 for the out?
is the output inpedance (before the output stage) about 10K?
thanks
600:600 for the input if your source can drive a very low load impedance. Otherwise, use 10K:600 and accept the additional 12dB of loss. Use 10K:600 for the output. In either case, the loss of the circuit will be substantial; I believe the nominal loss of the filter section itself is around 20dB.
Thanks Dave,
in case i'll use an 4k/600 that i have (military trafo),whats the load resistor i should use for flat response?
-im going from eq out into green pre for example.
i'll soon post some pics of the front panel made with transperancy film printed with an inkjet printer-its first time im using it - its easy and cheap and results are good.
The Pics:
Stock Pultec is
600:600 input (HS-56/66/66V)
20K:80K output (HS-29)
Good luck on the 29.
You should figure out which make-up amps you will be usuing mostly, solid mis-state or vaccum voodoo.
Three years ago, pics of a front panel would have gotten you a page of ooooh's and ahhhh's.
But due to an ever increasing number of insanely good projects, this rooom is a little tougher to work.
Very nice! What about a pic from them gutz?
not much guts to this thing.....just the gyraf pcb (thanks again jakob :thumb: ) toko inductors ,and XLR in and out,and the awaiting transformers...
i have an OEP 1604 (600/600) that i thought of using for the input (its very small :roll: ),will see how that goes.if not i'll try to use a huge Freed transformer (420/600) from evilbay....
the nice thing about this project is the box...I tried minimizing costs to almost nothing-using spare parts that i have, so i scabaged some Aiwa HiFi preamp,and went to the metal factory and had them cut me a 19" aluminium panel from leftovers....talk about cheapo diy......financial situation not so good.......cost me about 4$ for 2 panels .......
[quote author="CJ"]
[/quote]
You can get an ooooh from me. That's a really nice panel! Good job!
/Anders
Why not simply run the output un- or pseudo-balanced? After all, you won't be running long cables from this box to the preamp..
thats a posibility i'll definitly check.thanks.
one more thing i forgot to mention is that if anyone engaged in this project wants to have the graphics file just ask-its in psd or tif format,be happy to share.
