No microcontroller. Just manual SPST switches.user 37518 said:Are you going to be driving the relay with a signal (i.e. the output of a microcontroller) or with a manual switch? if you are driving it through a microcontroller you have to connect it to the base, if you are going to be driving it with a manual switch then ditch the transistor all together....
warpie said:No reason to switch the gnd. I asked just out of out of curiosity.
Do you think it's an overkill? I will probably use around 10 relays for things like polarity flip, impedance, +48V (this sort of things).
I got convinced that transistor driven relay is the way to go but only if it's necessary
user 37518 said:Why do you need a transistor when a switch will do a better job?, transistors are useful when your controlling signal cannot provide enough current to activate the relay. Otherwise just use a switch.
