Traynor Reverbmaster - capacitor substitution
GussyLoveridge
GDIY Supporter
Cape Breton, Nova Scotia, Canada
Hi Folks -
I'm having trouble sourcing a 125 uF 16 V cap for an amp I'm working on. Nothing close in a reasonably higher voltage either at Mouser or Digikey. I can find a 120 uF 40 V.
Can I substitute this? I mean they're +/- 20% right? So this should be close enough?
Schematic here: https://www.thetubestore.com/lib/th...aynor/Traynor-Reverbmaster-YRM1-Schematic.pdf - it's the cathode bypass in V5B in the tremolo circuit.
Gus
Hi Folks -
Preferably replace it with the next higher value and not lower.
So 150uf would be it
I work on a lot of Traynors. This isn't a super picky component. Go with 120u or 150u, as others have suggested, and you'll be fine. Higher voltage rating the better based on the footprint.
Those YRM1's are one of my favorites! Enjoy!
