Triad Magnetics
New member
- Joined
- Oct 11, 2023
- Messages
- 1
I called them once, they were not doing direct sales. Master Electronics has some in stock they are not cheap.Do you sell small quantities (i.e., 1-2 pcs) of J-series transformers? And if so, is there a price list? Thanks!
We are working on getting datasheets for all the J Series completed and uploaded. Check out the datasheet for the A-11J. What additional details would you like to see?Cool can we get some more in-depth datasheets for the J Series Audio Transformers, the website is very lacking.
www.OnlineComponents.com is stocking them. Unfortunately, they are expensive to manufacture. We're building them in our California facility (USA) using the original paper-layered winding method, nickel lamination and deep-drawn mu-metal shield cans. We've upgraded the lead-wires to higher temp Teflon insulation vs. the original PVC making them easier to solder. In any case, the A-11J was $19.20 each in 1960, adjusted for inflation that would be $199.65 in 2023, so the price has actually decreased: www.onlinecomponents.com/en/triad-magnetics/a11j-12695159.htmlI called them once, they were not doing direct sales. Master Electronics has some in stock they are not cheap.
Yes, the HS series is slated for reintroduction as well, but only these models at this time as they all use the same deep-drawn mu-metal shield can: HS-1, HS-4, HS-5, HS-8, HS-23, HS-25, HS-27, HS-29, HS-50, HS-52, HS-54 and HS-56.Planning to bring back HS series?
"Only" those? Darn (kidding, this is great)Yes, the HS series is slated for reintroduction as well, but only these models at this time as they all use the same deep-drawn mu-metal shield can: HS-1, HS-4, HS-5, HS-8, HS-23, HS-25, HS-27, HS-29, HS-50, HS-52, HS-54 and HS-56.
I tried emailing them recently (a few days ago?) regarding the HS-52… To see if they’re available to order yet, or otherwise, if they had any idea when it’ll be ready, but no reply.Has the HS series made it into production? I see them listed on the website, but I'm not having any luck finding them for sale anywhere. Direct order only, perhaps?
Yes there are a few out there: https://www.masterelectronics.com/en/keywordsearch?text=Triad+HSHas the HS series made it into production? I see them listed on the website, but I'm not having any luck finding them for sale anywhere. Direct order only, perhaps?
