Excellent suggestion, moamps. however I would recommend modifying the values according to this:
R3, 4, 5, 6 = 15k.
R7=10k
VR1=50k (47k)
With the original values, the gain range is huge (+/-13dB) and unity gain is cramped at one end of the trimmer.
Considering the OP needs basically unity gain, the proposed values offer a gain range of -2 to +4, which will make the calibration much easier.
Since the output of the opamp is essentially zero-ohm, the series resistor should be 3.9k instead of 3.6.
Not that it makes much difference in operation, since anyway VU meters are not adequate for visualizing transients that can trespass the 100%fs mark of a digital chain.
