Tube Amp connections : 0V vs EARTH vs HEAT vs CURRENT
Any prediction on timeline?
Curious if there is a one line description of what you found needed updating. I would think that there isn't much changing in the world of tube designs these days.
I'm hoping to get it out later this year, keep an eye on my website for any update. There isn't much that changes in the world of valves, but there are always changes that can be made to my books! This one is getting quite an overhaul, with less useful stuff removed and whole new chapters on new subjects added...
I’m ready to post some more specific information here, with one key question below. This is all a learning experience. This is for fun, but I’m being careful. I am aware I’m creating fire hazards for the time being.
I’ve finished re-housing / re-building from scratch a 1950’s Hi-Fi amp. It was a receiver unit that has a radio. I was interested in repurposing the amplifier / audio section as a guitar amplifier, putting that in a new enclosure situation, then leaving the radio section in the old chassis to utilize that separately some time in the future. So that’s what i did, but i also divided the power section from the audio section. So i have two small units, power, and audio. The radio stuff is still sitting in it’s old chassis, unused for now.
I followed the grounding advice given here in this thread, along with the filter/0V distribution described in the valvewizard article on grounding, implementing a heavy gauge bus rail for 0V. Everything seems to be working great. All noise is FAR far quieter, which is very exciting and a nice success.
The obvious complication when deleting a whole radio section of this unit is that I’m now missing that whole load of a bunch of tubes/circuits, so all B+ is going to be too high.
But before we get there… a side note… when deleting the radio segment, i pulled a 5.6K high wattage resistor, so i had that available. And it has a tap @ 100R, with 5.5K being second section, so a total of 5.6K.. This is indicated as R59 part A and B, in the posted schematic below.
As expected, when powering up my new system that did NOT have the radio 5.5k + circuit load on it, and with no mods to compensate for this, the main B+ voltage is of course too high. It settled around 410 DC where as it should settle at 360 DC. So I figured, let’s have fun and try hooking up that high wattage 5.5K resistor section loading B+ to 0V just to see what happens. I know it’ll get hot as hell and i might even damage things or start a fire, but a short trial might teach me something. Worst case i destroy my amp and use my fire extinguisher haha. This power resistor is pretty large, at 3 inches long and 5/8” thick, so maybe it can handle some short term heavier wattage.
So i added the two mods drawn in light blue below. The other mod is a 7W 125R resistor I happened to have on hand. Figured maybe it would help lower voltage, assuming I’d be too high still. And on first power up, I ended up with an absolutely spot on 360 DC B+ rail. Bizarre. This is pure luck of course, since this in no way resembles the whole radio circuit.
But yeah, the 5.5K to 0V gets hot. You wouldn’t want to touch it for more than a second, or even less. Also, the neighboring components are now quite toasty. The added 125R resistor is hot too, but not as much.
This is not a safe or permanent setup. But man, the sound of the amp is exactly as original, sounding incredible but now also very quiet, so i know the dummy load mods are functional to whatever degree.
What can i take from this? Can i simply but a much higher wattage 5.5K resistor as this dummy load and call it a day? 100W perhaps? Maybe the heat will be handled by the resistor and it won’t fry neighboring components? According to my understanding, my setup sends nearly 25W through this resistor, as well as around 65mA. That’s a lot of lost energy. However, i suppose that if I’m nailing the 360V DC with this, it perhaps means that the original radio circuit is burning exactly that same amount of juice? Obviously the power transformer already was designed to provide DC current to a whole host of more tubes, so maybe it has around that much to spare anyways, and would be the reason the voltage is now back to spec.
Below is a clearer sketch of the original power circuit, and the two mods in light blue that give a 360V DC B+ result. The original schematic is weird to trace, so this is much better.
In a dreamy ideal world, i would have a toggle switch that allowed me to either engage this dummy load, or engage a connector that send this original B+ rail through 5.5K to the separate radio unit. Then I can power up the radio with this same power supply and audio amp. The radio tubes and indicator lights were all on their own 6.3VAC, and right now i just have one indicator lamp hooked up. The voltage is probably too high but i haven’t checked yet. I could install a drop down high wattage resistor there too.
One great perk of this setup is that the high voltage gets drained almost immediately after power down. Maybe a handful of seconds. That’s really handy!
The 5.6K isn't needed. Just increase the new 125R until your b+ is back down to 360V.
Ok got it. Whenever i attempt to achieve that within PSUD2, it is difficult to get the voltage to lower that much. The load at the end of the line in PSUD2 is difficult to create so as to mimic reality, and i think that’s what is making it difficult to simulate voltage drop.
Any guesses as to what value and wattage will safely drop the rail 50 V (360 down from 410) in this spot where i have the 125R? Experimental shopping for power resistors really adds up in cost. I could get an adjustable power resistor though, high wattage. So maybe that’s the best attack, if i can just figure out a rough target value first. Maybe I’ll try installing the 5.5K there and see how low it drops it.
V=IR (Ohm's Law)
Rearranging R=V/I, so you need to know the circuit current, then you can calculate what resistor will drop 50V with that current. No need to guess, but you do need to measure.
V=IR (Ohm's Law)
So measure the actual current draw of the whole DC rail of audio amp. Safety assumed, I guess the best way to do this is put the meter in line at the beginning of the B+ line somewhere? The reason I say this is that interrupting a 0V leg seems confusing since 0V is not actually returning anywhere except for the chassis point at input jack. Or can I in fact get a current reading between 0V of first cap and 0V of rectifier or something like that?
Current always flows in loops, the current is getting back to the power transformer somehow. When the current does not actually return that is called an open circuit, and all the devices stop working.
Do not get complacent with the "0V" connection, when you break the connection to insert a meter, if there is power applied (or even power off but capacitors still charged) the high side of that connection will go up to the B+ voltage. Hopefully you know that, but in case you don't make sure you don't shock yourself trying to connect your current meter into your 0V connections.
If only the chassis is used for the return path, then figuring out when you can reliably interrupt the current to measure is possibly trickier than it is worth, so measuring on the high side would be the most reliable.
You should be able to, but that will be pulsed current, so might be hard to interpret. Your meter should average it and show the RMS current.
By the way, did you mistype? 0V of the first cap connects to the center tap of the transformer according to the schematic you posted, the rectifier connects to the transformer and to the high side of the cap, there is no "0V of rectifier" connection.
Ah yes, that’s what I meant! Meant to say 0V of transformer.
And yes I already consider 0V to be just as dangerous as the B+ since it’s all the same signal finding its way home.
I’m glad you mentioned about the power being pulsed because I forgot about that factor in this context. I’ll just go ahead and measure the B+ rail current draw. I believe my Fluke DMM will handle it fine but I’ll double check the max voltage.
Thanks for the tips, I’ll report back. One other question.. with said 5.5k high watt resistor sitting where it currently is, from B+ to 0V, the B+ is perfect 360V as the amp was designed. Should I measure current draw as it stands now? Or should I delete the 5.5k resistor, and let the B+ sit high at 410V and measure current like that? I do worry about over voltage somewhere but maybe it’s fine.
You can measure with the 5.5k removed, or measure with, and then subtract the current through the resistor from the total to get the current of just the circuitry. At 360V the current in the resistor would be 360/5500, or 65.4mA, so you can just subtract that from the total you measure with the resistor in place.
That might be more accurate, possibly the circuit draws slightly more current at a higher voltage, and current at the desired voltage is what you want to know.
Never use an inline current meter if you don't have to, it's just an invitation for mistakes. Instead measure the voltage across your 125R resistor.
Current = Voltage / Resistance.
Now you know the current.
You could even measure the voltages across each resistor in the power supply, allowing you to calculate the current at each branch in the circuit, and you can plug those numbers into your PSUD model.
Well that’s inticing and a heck of a lot easier than desoldering and resoldering major power connection points!
Can I work backwards from the final preamp stage and measure drop across its resistor to determine current, then measure drop across resistor/stage prior to that and then subtract that other (final) stages current to get its resulting current too? And keep working backwards? Is that how it works? Since it’s all in a line, following it backwards I’m guessing each successive current draw is included in the one before it?
I suppose if I can get separate current draws per stage, i can then add a “constant current tap” at each filter in PSUD2 to create each actual measured current draw at each stage?
If that’s the case, I can fully recreate my system and just start increasing resistor values at the 125R location until my first rail reads 360V.
